Configures whether IP forwarding must be enabled on a VLAN before transmitting IP packets originated by the switch on that VLAN to a gateway.
| require-ipforwarding | Specifies that IP forwarding must be enabled on a VLAN before IP packets that originate on the switch can be transmitted to a gateway. |
| dont-require-ipforwarding | Specifies that all IP packets that originate on the switch can be transmitted, regardless of the IP forwarding configuration to the gateway. |
dont-require-ipforwarding.
To display the current setting for this command, use the show ipconfig command.
The following command configures the switch to transmit switch-originated packets to gateways only on those VLANs for which IP forwarding is enabled:
configure ipforwarding originated-packets require-ipforwarding
This command was first available in ExtremeXOS 11.6.
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
